Blah Blah Blibbidy Blah!
And on sunday of all days, the mail is delivered! Very odd. Anyway, I got the red handle stick, with both 25*C and 80*C readings. I know those are in celcius, but the temp readings on the van dash, are those celcius as well? Since its winter, and I have no idea when its 25 in the van, I know that my vans running temp is 80. That temp gauge I can follow for my tranny oil temps as well?
If yes, then after I get the temps to 80 can the cap to test the oil level be pulled off without worry of pressure and what not, or should I take the cap off first before getting the temps up? Dont want no hot oil blowing all over me! |
#2 |
Aztek
The system is not pressurized. Run your truck for 1/2 hour on the road to be sure the oil is warm. If the dipstick is a MB, you'll find it is just a tool and cannot be left in the filler tube. You'll find that the dipstick is proud about 3" from the dipstick tube when fully inserted...so don't try to force it. Make sure you run it through all the gears (foot on the brake) and finally put it in park and leave it idling before making your measurement. Also, that little red tamper seal is a bit tricky. Break the head off, and then push it downward with a small screwdriver and coordinate that with pulling off the cap at the same time. Buy some extra tamper seals before going back to the dealer for any issues. |
#3 |
06 T1N Can
There's a thermistor in the transmission that is hooked up to the TCM (Transmission Control Module). You can measure that pin using an ohm meter to find your temperature.
Otherwise, I would just go this route... http://sprinter-source.com/forum/sho...99&postcount=2 ...and measure your ATF level. Drive it and get the Sprinter up to operating temperature and just measure. Don't have to get to fancy about it unless you want to. |
#4 |
I saw the tech use a generic looking dipstick to check my levels. So I am wondering, is there a cheap generic ATF fluid dipstick out there for a lot less? I mean, all it has to me is long enough and have some indicators at the end. That's all they used at the "Ceritified Sprinter Service station"
Matt |
#5 |
Innovan
I would be very cautious using anything else but the MB tool. I found that the tool is designed to bottom out inside the transmission (probably to remove tolerance stack-up error) instead of against the filler tube end. If you use anything but this tool, be sure to duplicate the end of this tool carefully or your snake will go deeper into the tranny and give the impression of more oil than there is suppose to be when you will actually be low on fluid. I don't know what you were quoted but I bought mine for $59. I personally wouldn't fool around trying to save some:2cents in this department |
#6 | |
06 T1N Can
http://sprinter-source.com/forum/sho...57&postcount=1 ...you can find the dimensions to making one yourself or find something similar (cheaper) to do that job. |
#7 |
Is there an online store that sells the tamper seals, or should a dealer sell them readily?
#8 | |
06 T1N Can
http://europarts-sd.com sells them. |
#9 |
its safe to just run without the red clip? I do remember reading on this forum in the past about someone re-using the cap without the redclip, but I couldnt find that entry. The dipstick is SO very long so I know there isnt going to be ATF sloshing out. Warrenty is up, so who cares. And since it doesnt work on a pressure system... well, you see. If I dont need one, all the better, but does the cap sit nicely on the tube without worry of falling off and being lost forever?
#10 | |
06 T1N Can
http://sprinter-source.com/forum/sho...69&postcount=3 I've had it like this for over 10k miles. |
| Thread Tools | |
| Display Modes | |
