sikwan
06 Tin Can
I didn't change my fuel filter at the 10k miles mainly because I didn't know that I had to. It's now at 20k, so I thought I'd include the fuel filter change. This is for a 2006 T1N.
Tools:
T20 Torx Bit (water sensor screws)
T30 Torx Bit (filter body clamp)
Needle nose pliers. (hose clamps)
Part number on the box.
The filter. It comes with two o-rings and a plastic sleeve.
I'm not sure what the plastic sleeve at the base is for. Plastic sleeve is to make up for the difference in circumference near the bottom of the filter, for clamping reasons.
This P/N is different from what is on the box.
Bought some worm gear clamps at the local hardware store (OSH).
99 cents each. Made in China. I hope it lasts.
Removing the clamps.
Tools:
