Old 07-27-2012, 03:47 PM   #1
Bene Did It
Question Navion Engine Battery
How do I check/replace the battery for the engine. I believe it is under the driver's seat. 2008 Navion iQ. Thanks
Bene Did It is offline   Reply With Quote
Old 07-27-2012, 05:05 PM   #2
claudalfa
Car Crazy
claudalfa's Avatar
Default Re: Navion Engine Battery
On my 2008 Winn View built on 2007 Sprinter,battery is located in the floor ahead of driver seat, just remove the floor covering and unscrew the plate and voila your battery is there
Winnebago View 24J
Sprinter 2008 3500 Chassis
claudalfa is offline   Reply With Quote
The Following User Says Thank You to claudalfa For This Useful Post:
Bene Did It (08-04-2012)
Old 08-04-2012, 02:30 PM   #3
Bene Did It
Thanks Claudalfa, the battery was right where you said. For some reason, I thought it was located under the driver's seat; glad to find it easy to get to. I checked the water level, which was my concern, because I like to keep a float charger on in the off-use times. It was kind of you to reply.
Bene Did It
Old 08-05-2012, 10:45 PM   #4
claudalfa
Car Crazy
claudalfa's Avatar
Thumbs up Re: Navion Engine Battery
I check battery water level every 6 months and coach batteries do need distilled water every time
Usually half a gallon will go in
2008 and still the same batteries every where and. No sign of failure and we have been full timing for over a year in our View
Good luck
Winnebago View 24J
Old 08-05-2012, 11:03 PM   #5
Mrdi
Mrdi's Avatar
In the 2008
Thought the battery under the driver's foot-bed was sealed and
the battery under the hood (OEM) was in need of maintenance
Mrdi
2008,2500, 144 Hi Cargo
Surf City USA,
Southern California
Old 08-11-2012, 03:19 AM   #6
T.J.T
T.J.T's Avatar
I knew nothing about this battery maintenance... seems like I have some reading up to do. Sigh.
2008 Dodge Sprinter 2500
Used for my Blind Installation company!
T.J.T is offline   Reply With Quote
Old 08-11-2012, 03:58 AM   #7
Altered Sprinter
Altered Sprinter's Avatar
Originally Posted by Mrdi View Post
In the 2008
It depends on the battery options,as to OEM or aftermarket uplifter fit-outs.
No Shalam - No Shalom
autostaretx (08-12-2012)
Old 08-12-2012, 12:37 AM   #8
Mrdi
Mrdi's Avatar
Just pulled the cover over the foot well on my 2008 Cargo w/ an OEM 220 amp alt.
I have the 100 amp aux under the hood and an EE8 under the foot-well 100ah.
BOTH of my OEM batteries are wet.
Each cell (6) took 6 OZ of distilled water.
Thanks Richard!!
I thought the starter battery (foot-well) was dry.
It is wet!!
Thank goodness it wasn't dry when I checked.
Mrdi
Surf City USA,
Southern California
battery replacement, engine battery
