Old 07-27-2012, 04:49 AM   #11
skill3
2006 Dodge T1N 2500 118"
Default Re: Shipping container fit
I don't know if you are aware, but there is a "high cube" container. The door opening is 2.58m, internal height is 2.70m. Good luck.
skill3 is offline   Reply With Quote
Old 07-27-2012, 09:13 AM   #12
elipsoid
Thanks for the tip, I mentioned the high-cube in my previous post. But that would make the shipping more expensive (plus not all ports have high-cubes readily available), I would like the van to fit into a regular container.
elipsoid is offline   Reply With Quote
Old 07-27-2012, 02:36 PM   #13
NelsonSprinter
Nelson BC Sprinter Owner
NelsonSprinter's Avatar
Getting a heavy pallet placed in the rear may lower the back end 1-2", compressing the suspension and tires, lowering the air pressure to 8psi may lower it 1-2". Sorry no experience
'02 FL 2500 140WB Cargo door windows, 15" Alloys, LT235/75R15-E Nokian Rotiivas, Nokian Hakka C studded winters, Curt 4 hitch, 3.72 rear with 30MPG Canadian
Old 07-27-2012, 02:38 PM   #14
elipsoid
And how about completely deflating the tires?
Old 07-27-2012, 02:52 PM   #15
That can be done. The tires may be damaged running them uninflated even at slow speeds.
Most likely the tire to wheel seal (bead) will break loose from the rim while moving the van around. Once that happens the tire will need to be re-seated to the rim before you can re-inflate the tire. Not an easy task on a loading dock, but it is possible using an inflatable tire band while the wheels are in place.
You mentioned RORO. I've heard some horror stories about damage and theft of vehicles using that method. The longer the vehicle sits unattended on the dock the more it increases that probability. vic
Old 07-27-2012, 03:05 PM   #16
elipsoid
Good point on breaking the seal, I didn't think about that. Thanks!
I've heard the same horror stories and also know some people that used RORO without larger problems.
Old 07-28-2012, 12:30 AM   #17
jdcaples
Not Suitable w/220v Gen
jdcaples's Avatar
Hi, I am considering buying a T1N low roof Sprinter for a little adventure that would involve shipping the van. According to the data I have, stock sprinter is 2345mm high, while standard container door is 2278mm. I figured if I let some air out of the tyres, it should fit. But it would be a very tight fit. I wanted to ask if somebody tried shipping their Sprinter and could confirm my theory. Thanks!
Shouldn't this problem be solved by the shipping company? They should have specs on the size of things they'll ship. Sprinter-source forum members would be "users" of the service. I'd talk to the professionals providing the service.
-Jon
Old 07-28-2012, 12:32 AM   #18
elipsoid
The measurements are taken at the port, as far as I know.
Old 07-28-2012, 02:33 AM   #19
Type2Teach
Broken DAD Owner
Type2Teach's Avatar
Is there another vehicle that has 5x130 bolt pattern that has smaller wheels? It doesn't really matter what the weight rating is on the tire, if all that is being done is to drive it in and out of a container. Right?
Joel in Philly
'02 2500 140" Passenger 113K miles
'06 2500 158" Passenger 338K miles
'79 VW T2 9pass Electric project- for sale!
Do you know *exactly* how tall your van is? Measure it and write the height on your sun visor. Don't make the same mistake I did!
Scan Tool List-> http://sprinter-source.com/forum/showthread.php?t=16023
Injector leak off test-> http://sprinter-source.com/forum/showthread.php?t=17149
Type2Teach is offline   Reply With Quote
Old 07-28-2012, 03:35 AM   #20
'Rett Butler
How much "travel" does a Sprinter have? Could you use ratchet straps to compress the suspension? Then you can solve your "securing" it inside issue by just releasing the straps.
:) kidding of course
'Rett Butler is offline   Reply With Quote
