| NCV3 Write-Ups Help other NCV3 owners by posting your experience working on your Sprinter. |
I have a 2008 Dodge NCV3 with a cracked driver's side turbo hose. The rubber is cracked at the metal end of the hose. It gave me the occasional limp home home performance until I spotted a small amount of oil on the outside of the hose.
Thanks to all who have contributed to the closed threads on how to spot this problem. My question is should I replace with a new hose ( even thought it was produced on 1/16/08, it appears to have the new "?" shaped hose) or do I try the Riordanco ADAP09 Turbo Hose Adapter? It looks like the trade off might be tearing the stock hose again (the van is an RV with only 13000 miles on it) or blowing the hose clamp off the Riordanco fitting. Thoughts? |
#2 | |
Recalling some of the clamping problems encountered with the adaptors, were I needing to make a choice (I'm not) I would probably just buy an OEM part. Good luck. vic
#3 |
My vote is for OEM hose .
also if you can post a picture , cuz i read somewhere that the new shape hoses were like after may ,2008 trucks , correct me someone if I am wrong |
#4 |
Not Suitable w/220v Gen
I posted a picture - new hose and old hose - side by side here:
http://sprinter-source.com/forum/showthread.php?t=10345 They are shaped differently, but it'd be easy to confused. If the original poster confirms he has the newer hose, the Riordan solution is probably worth a try. -Jon
#5 |
Yes , FalconerTom , please confirm the shape of that hose , we all want to know.
I am still thinking what to carry with me in my van as an extra part - OEM hose , or Riordanco. |
#6 |
The up-dated hose continues to fail just like the “up-dated Q5 resonator" continues to fail on the T1N. I would suggest carrying the Riordan adapter in the event of an emergency (this is what I do). We do sell these along with Riordan’s other products. Hope this helps.
Thank you, John Sprinter Store http://sprinterstore.com/ A division of Upscale Automotive, Inc. 19460 SW 89th Ave. Tualatin, OR 97062 503-692-0846 |
#7 |
Neither of my hoses have failed.
The only person I talked to at SprinterFest with a failed hose was driving a motorhome close to maximum gross vehicle rated weight. He inspired me to get the new, updated part. I know that John Bendit (scubanw3) works on a lot of Sprinter RVs. In fact, most of the NW SprinterFest attendees come in motor homes. I'm curious if any 2500 US/Canadian Sprinters, carrying a nominal load of 500 - 1500 lbs have had failures. I travel over the Cascade Mountains regularly during non-snow weather. I don't think I put the same stresses on the intercooler hoses that "condos on wheels" put on the components. -Jon
#8 | |
![]() ![]() So.........is this max pressure failure or a time under some level boost failure or combination???? or just crappy German rubber or less than perfect inconsistent quality of the finished edge of the fittings or again some combination![]()
2008 3500 chassis Class C built in 2010 Pulling 6x12 enclosed trailer |
#9 |
The failure is a combination of everything mentioned. The majority of failures are on overweighed Sprinters especially the Class C’s or cab chassis with cubes on the back. At 11,000+ pounds, these rigs are almost always under 90-95+ % engine load which plays havoc on an oily turbo hose. The turbo hose at the bottom of the resonator pipe gets oil soaked and deteriorates resulting in the tear failure at the connecting flange. Since the flange crimp to the hose has a sharp edge, the oil soaked rubber tears from the constant bloating caused by the extremely high engine load and turbo pressures. The redesigned hose has a slightly different shape but the flange to hose crimp and the oil soaking issue remain the same. So, if you’re a lard ass, carry a Riordan adapter as a backup. Hope this makes sense.
#10 | |
Again, thank you to everyone who documented this problem in the past. It helped me pinpoint the problem quickly. |
| Thread Tools | |
| Display Modes | |
