Old 07-01-2012, 07:47 PM   #11
cahaak
cahaak's Avatar
Default Re: T1N AC, why does it struggle at temps above 90?
I have a 2006 passenger, glass all around (do have some good 3M window film on it). Up to about 95 degrees I can use only the front AC cool off the whole van, so something is wrong with your system. You need to have it completely evacuated and recharged and then run and they need to go by the pressure chart with temp that is in the service manual to make sure that it is operating properly. If it is operating properly, it will do a good job cooling off the van, especially with the divider that you have. If you do not have some good window films on the front side windows, I would highly recommend it. Get something with a high TSER - it does not have to be that dark.
Chris
2006 140" passenger
normal roof with rear AC
Old 07-01-2012, 09:57 PM   #12
Dingo
Originally Posted by shortshort View Post
After several cups of tea I'm the one needing a leak detector. Just sayin...
Thats an age thing
Dingo is offline   Reply With Quote
Old 07-04-2012, 09:03 PM   #13
Type2Teach
Broken DAD Owner
Type2Teach's Avatar
Chris
Can anyone point me in the direction of this AC pressure chart?
Joel in Philly
'02 2500 140" Passenger 123K miles FOR SALE
'06 2500 158" Passenger 338K miles
'79 VW T2 9pass Electric project- SOLD
Do you know *exactly* how tall your van is? Measure it and write the height on your sun visor. Don't make the same mistake I did!
Scan Tool List-> http://sprinter-source.com/forum/showthread.php?t=16023
Injector leak off test-> http://sprinter-source.com/forum/showthread.php?t=17149
Type2Teach is offline   Reply With Quote
Old 07-05-2012, 12:03 AM   #14
cahaak
cahaak's Avatar
The chart is in the AC plumbing section of the service manual, available from links here on the forum. The manual itself is about 40 MB and I'm not sure how to copy just one page. It is page 24-49 of the 2005 service manual and should be in a similar place in the 2006 manual.
Chris
2006 140" passenger
Old 07-05-2012, 09:02 AM   #15
Dougflas
DAD OWNER
Also make sure your condenser, radiator, and charge air cooler are clean and free of insects.
2005 TIN Sprinter 3500 and 2500
Located in Beverly Hills, Fl.
Old 07-05-2012, 11:00 AM   #16
Gulf SV
Kevin Burns
Gulf SV's Avatar
Here's the plumbing section of the 06 service manual.
HVAC_06.pdf
One thing I have not read yet is whether you had the freon level rechecked. Remember, there is a reason the freon leaked off in the first place. It could be as simple as that. As was mentioned, you do not need a Sprinter service tech to maintain the system. There is absolutely nothing special to deal with.
If you don't trust your shop, find one you do. I would be surprised if they didn't add in or suggest a dye pack to monitor for leaks. And replacing the dryer is generally a good maintenance decision.
When I bought my van, the AC did not work. We (they) found a rotting radiator and replaced it. To save many dollars, I salvaged the hoses (one is OEM only and $$$). System was charged, dye added for future diagnostics, and outlet temp was measured at 45°F (MB recommended). That was two years ago, and the system still drives me out if I don't regulate.
Good luck. We're in our third week of +90° temps and tomorrow's forecast is 102°. Happy to have my AC.
Kevin Burns
motorcycle racing freak
06 Freightliner 2500 SHC 158"
160,000 miles
Gulf SV is offline   Reply With Quote
The Following 2 Users Say Thank You to Gulf SV For This Useful Post:
Jsloane (08-19-2012), Type2Teach (07-05-2012)
Old 07-05-2012, 01:46 PM   #17
Type2Teach
Broken DAD Owner
Type2Teach's Avatar
Chris
I tried to download it yesterday and the link didn't work.
Joel in Philly
Old 07-05-2012, 03:28 PM   #18
cahaak
cahaak's Avatar
Joel,
Page 24-65 in the posting above by Kevin is the pressure chart. That data should help the AC tech get the charge right.
Chris
2006 140" passenger
The Following User Says Thank You to cahaak For This Useful Post:
Old 07-05-2012, 06:22 PM   #19
Dingo
Take the grill out & spray bike chain degreaser over both rads , leave for 30 mins to work its magic . Then wash off using only a hosepipe from behind forwards . Bike cleaner will not affect alloys or plastics/ rubbers . Do not use a pressure washer as you will most likely blow through the rads .
Oily crud & formerly flying insects form a lovely crusty coating on the rad fronts blocking off the air flow , I am aware of one soul who has fitted a black net material behind his cars grill to catch this ****e . This is changed twice a year as he does very high milages each year 120,000 miles +
The Following User Says Thank You to Dingo For This Useful Post:
northener (07-05-2012)
Old 07-05-2012, 08:00 PM   #20
Boater
Muck Off!
I mean, good idea I always have some of the above brand bike cleaner around, I'll get onto that once I have the radiator off!
