Old 05-13-2012, 11:25 AM   #1
Pilbara
Pilbara
Default Hydraulic crane
Hi. I have a 519 LWB 4x4 drop side tray. I have a Palfinger hydraulic crane that I intend to fit. Question is up by cab or at back of tray. Anyone one care to share ideas or experience of cranes in either position. Pro & Cons?
Just general lifting and motorbikes.
Cheers
KB
Pilbara is offline   Reply With Quote
Old 05-13-2012, 09:15 PM   #2
Altered Sprinter
Altered Sprinter's Avatar
Default Re: Hydraulic crane
Cheers
KB
Hi KB there are mounting points on the Sprinters chassis as a specific guide for mounting cranes and towers, I'd have to look at the type of crane your fitting to find the link from Mercedes Body builders portal. If close to a MB sales contact they could send you the information via email.
Richard
No Shalam - No Shalom
Old 05-14-2012, 03:44 AM   #3
Altered Sprinter
Left hand side facing cabin
If used at rear right or left a supporting jack will be required for a crane lift irrespective of weight limits of Center of Gravity as the risk of compressing the rear parabolic spring set and damaging the said springs.
MER0109 Sprinter AWD Cab Chassis Spec Sheet_FA_WEB.pdf
Basic 4x4 spec sheet for Australia
arl_sprinterbm906_en Richard.pdf
Euro 2010 Body directive file; large file takes time to down load.
Look from page 127 for loading points.
Looking at your website I don't think your going to have a problem sorting this one out.
Cheers Richard
Old 05-14-2012, 11:51 AM   #4
Eric Experience
Eric Experience's Avatar
KB
It is a good question, and the answer is go for rear if you want to reach into sheds or pick up on the road. But if you want to be able to carry cars you have to go for the front mount. When mounting on a sprinter it is best to avoid clamping around the shassis as it can crush, Take all the load into the tray and stabiliser legs. Run the pump from its own battery, and charge that battery from the alternator via a relay energised from the D+ terminal, Sprinters do not like low battery volts when starting. Eric
Old 05-14-2012, 12:21 PM   #5
Altered Sprinter
Eric with respect, if you bothered to understand the Sprinters dynamics as to tolerances of the guideline parameters, there are exacting mounting points for the Hydraulic stabilizer bars.[IF USED?] or 'If' drilling into the chassis rail is required then the highest point towards the tray,{eg} top rail there is a clear-directive provided by Benz and certificated to ISO standards,of which includes bracketing. The tray provided by Benz is alloy, the real strength lays in the optional H/D 6 plus mil weatherproofed Masonite composite on top of the tray.
Richard
