Old 05-02-2012, 09:09 PM   #1
papap
Default Oil change
Changed oil in sprinter today. I got the interval Reset. But now th engin light is on. Check level and it looks good. Anyone have a clue what to check?
papap is offline   Reply With Quote
Old 05-02-2012, 09:24 PM   #2
papap
Default Re: Oil change
Oh and now instead of just the small wrench it has a bigger wrench also. But it did change mileage to 10000.
Old 05-02-2012, 10:12 PM   #3
Leetard
Gnarcissyst
Leetard's Avatar
What year sprinter do you have.
Leetard is offline   Reply With Quote
Old 05-03-2012, 02:41 AM   #4
papap
It's a 2011. I all o the guy at Dodge service center. He thinks I ove filled oil. I'll drain alittle out in morning and we what happens.
The Following 2 Users Say Thank You to papap For This Useful Post:
Maximan (05-13-2012), Mrdi (05-13-2012)
Old 05-03-2012, 03:07 AM   #5
sailquik
sailquik's Avatar
Question Re: Oil change
papap,
What oil did you use?
How many quarts (liters) did you put in?
If you overfilled it you should get a warning in the console that says "HI".
It's definitely not a "greeting".
Old 05-03-2012, 11:38 AM   #6
icarus
Depending on the dash display config, you might get a CEL for high oil. Use a vacuum pump to draw out 1/2 quart. Check it with the dip stick first.
Icarus
Old 05-03-2012, 03:12 PM   #7
papap
Ok. I use Mobil 1 oil that is rated 229.51. I drained some oil out. It shows about half way between min and max on dipstick. It lets me rest the 51 screen But engine light is still on and on oil change interval screen there is a small and larger wrench. Also on one screen it shows a code 0208. Anyone have any clues?
This is a 2011 model with no steering wheel controls.
Old 05-12-2012, 11:18 AM   #8
AGP
AGP
AGP's Avatar
I have a 2008 and the mb dealer said light is very sensative. Real issue and tiny amounts either under or over will cause it to come on. I get a oil can indicator
AGP is offline   Reply With Quote
Old 05-12-2012, 03:24 PM   #9
sailquik
sailquik's Avatar
Papap,
Did you also refill the DEF fluid?
I have a 2011 MB Sprinter without the steering wheel buttons but I'm only at 6500 miles so I'm not sure how the DEF warning displays yet.
Since oil changes and DEF fluid refills both occur at 10K miles you could also be low on DEF.
Old 05-12-2012, 05:37 PM   #10
showkey
Papap,
That would be sad if Papap's other thread CEL after oil change is low DEF
2008 3500 chassis Class C built in 2010
Pulling 6x12 enclosed trailer
showkey is offline   Reply With Quote
The Following User Says Thank You to showkey For This Useful Post:
Yeehaw (06-10-2012)
