Old 04-20-2012, 12:44 PM   #1
MIK3
Question Hi Line Service reset not working?
I cant figure it out for the life of me. I have used the directions on the attached page for the last couple of services, and for some reason I cant get the "bee" by holding the button. As a result I cannot enter the menu to rest.
Do you know why this is happening?
MIK3 is offline   Reply With Quote
Old 04-20-2012, 12:50 PM   #2
Altered Sprinter
Altered Sprinter's Avatar
Default Re: Hi Line Service reset not working?
I was under the impression on the older NCV NAFTA sprinters>>>> it was a dealer re-set only.
Richard
No Shalam - No Shalom
Old 04-20-2012, 08:49 PM   #3
MIK3
Richard
Thats what they told me, but I found this document and have used it successfully before.
Old 04-20-2012, 11:14 PM   #4
Leetard
Gnarcissyst
Leetard's Avatar
Word for Word instruction sheet that I have:
-key position 2
-doors closed
-Miles/ tripe displayed using page button
-arrow button up until "service scope in XXX" appears
-press "O" button on Instrument cluster and hold, release after the beep
-press lower left steering wheel button "menu back" once
-Select "Service scope in XXX" with arrow buttons
-Briefly press "O" button on IC, menu "To be carried out" appears
-select "full service" using + and - buttons
-Confirm with upward arrow (used as enter button)
-"oil type" menu appears
-select 228.51
-confirm with upward arrow button
-Press "O" button on IC for 3 seconds to confirm
Leetard is offline   Reply With Quote
Old 04-21-2012, 12:04 AM   #5
jdcaples
Not Suitable w/220v Gen
jdcaples's Avatar
-key position 2
-doors closed
and that's where it ends for some of us. I've heald the O button on the instrument cluster for 20 minutes (no, I'm not exaggerating). No Beep.
-Jon
Old 04-21-2012, 01:01 AM   #6
HappyFamilyVan
Captain Ahab
HappyFamilyVan's Avatar
I just tested mine....A couple of key points...I am sure you already did this so please forgive if this is redundant...
1) turn key to pint where glow plug lght comes on...then goes out...turn no further...
2) navigate to the menu that says..." Service A or B in XXXX Miles"
3) push 0 button....beep in about 30 second
Good luck
'08 144 Passenger Wagon, Rear A/C, and a blow hole (sunroof)
HappyFamilyVan is offline   Reply With Quote
Old 04-21-2012, 07:13 AM   #7
Altered Sprinter
wasn't there supposed to be a software update on the reset, a few years back now..
Richard
