Old 11-21-2011, 01:08 PM   #1
alans09r
2007 Dodge Sprinter 2500
Question Intake Air Temp Sensor Location
This may seem very benign, but can anyone tell me where to find the Intake Air Temperature Sensor on a 2007 Dodge Sprinter. I bought it 2 years ago from Europarts and have never been able to discover where to install it. There are photos of other engines and models on this Forum but I didn't see a picture for the 2007. Thanks to anyone.
alans09r is offline   Reply With Quote
Old 11-22-2011, 02:26 PM   #2
jdcaples
Not Suitable w/220v Gen
jdcaples's Avatar
Default Re: Intake Air Temp Sensor Location
It's been a while, but I believe it's on the left-hand side of the turbo charger, as you're looking at it (aka right/passenger side of the vehicle), under center engine cover. It's closer to the turbo charger than the air cleaner housing.
If I recall correctly, to expose it you'll have to remove the air cleaner and the center engine cover.
Since few (maybe zero?) members driving a 2007+ Sprinter have reported an Intake Air Temperature Sensor failure, I've not bothered to hunt it down photograph it.
Please take a picture of it and post in NCV3 Database, including the pieces you had to remove to find it.
-Jon
PS: this should probably be moved to NCV3 Talk
Old 11-24-2011, 04:28 PM   #3
alans09r
The reason I bought it was because Europarts suugests it is an item that fails and causes limp mode. Will get some photo when I install it.
Thanks again
Old 11-25-2011, 03:43 PM   #4
Gessippi
Did mine yesterday, it's on the passenger side just above where the intercooler hose plugs into the motor at about 11 o'clock if your on your back, feet pointing out the front.
My sensor had watery goo on it, I removed the hose and there was a bit of oily watery snot sitting at the bottom that needs to be cleaned out. If I had to guess I'd say once the sensor wires are coated in this snot it will show a fail code and just needs cleaned.
Gessippi is offline   Reply With Quote
The Following 2 Users Say Thank You to Gessippi For This Useful Post:
alans09r (11-27-2011), jdcaples (11-25-2011)
Old 11-27-2011, 07:39 PM   #5
alans09r
Dear Gessippi and Jon:
Thankyou so much for your responses.
When the snow in my driveway drops to less than 4" I'll get under my van and see if I can replace this unit per the information of Gessippi.
Europarts advised this part causes limp mode which is why I bought it a long time ago, "just in case". I know however this condition isn't simply analysed and in fact can come from a variety of sources.
Jon, per you're response, which I truly thank you for; I did take the cover off the left (passenger side of the engine) which included a thick foam rubber membrane (over an hour to re-install) just to see if this illusive part was hidden in there beyond the top cover - but its simply not there.
A great thing might be "Solutions" category separated by Sprinter years because 2007 and up seems to be a different animal across the board.
The main conclusion I have come to however is that "little things" like a sensor that has the ability to cause "major problems" or cripple a vehicle - information which is so important, would cover more practical use of the space on this forum than many of the inane posts I see from time to time.
Old 03-08-2014, 07:23 PM   #6
rpmckee
Mercedes doesn't make this sensor easy to find. I have a 2009 Sprinter and have been looking for about a half an hour and can't find the damn thing. I have the part but cannot find where to put it.
rpmckee is offline   Reply With Quote
Old 03-09-2014, 01:02 PM   #7
rpmckee
I found it in a 2009, unscrew and move the coolant reservoir out of the way, so you can get your arm in there, and feel around back of the back of the air tube just above where the rubber hose attaches. There is a coolant hose or something in the way that makes it hard to reach.
Took me about 2 hrs to find this damn thing, hope this helps somebody.
I tried to take a pic but I couldn't get a good angle.
Old 06-22-2015, 03:04 PM   #8
ringnalda
ringnalda's Avatar
OK Guys, I just changed this sensor, it is a 10 minute job (if that) but don't do this from the top, do it from underneath. I didn't even need to use a lift; just lie on the floor on the passenger side and look up, you can see the alternator, and the turbo hose just above it. The sensor is right there, undo the little plug, pinch the sides of the sensor and it pops right out.
ringnalda is offline   Reply With Quote
