#11 | |
By the way, where did you get that awesome roof rack? I love it! Thanks |
#12 | |
Sorry about that window misunderstanding, I just assumed the rear windows were covered for privacy. I guess I missed the crew van memo. I made the roof rack. In my write up I have some details about its fabrication. I would be happy to provide more info if you're interested. |
#13 | |
![]() Thank you! |
#14 | |
Schloss auf Rädern
Her name is Cambinos! She is our Schloss auf Rädern (castle on wheels). Track her development here and her adventures at Living Appalachian |
#15 |
John-
That looks freaking awesome!!!! Where have you driven it to so far?? Just curious... |
| The Following User Says Thank You to danelgran For This Useful Post: | John 3:16 (07-23-2011) |
#16 | |
#17 |
Hi nice work with the conversion.
I was looking at you rear camera. What is you field of view like with the camera positioned by the number plate? I want to fit a camera to my Sprinter but as yet haven’t decided on a make or fitment position. Cheers Dave |
#18 |
I had the same concern when I was installing it. It really isn't that far off center when you consider that I mounted it to the far right side (facing the license plate) of the trim that overhangs the license plate. The field of view is fine. I can even see the step that I put on the hitch when I'm backing up.
| The Following User Says Thank You to John 3:16 For This Useful Post: | wookie_73 (07-25-2011) |
#19 | |
Schloss auf Rädern
| The Following User Says Thank You to BillWV For This Useful Post: | josher (05-03-2012) |
#20 |
Yes, I fished it through the existing loom. The trick is to peel the rubber from the flexible conduit from the hard plastic attachment grommet. Then you will have to carefully remove the plastic grommet from the opening (this is the hardest part) and re-assemble it to the flexible rubber conduit. Once you have everything opened up, it is easy to fish the wires through. Putting the flexible conduit back into the door and body is easy. You just push the ends in until they "snap". Do not try to fish the wires through while the flexible conduit is in place. You'll just spend a lot of time becoming frustrated. Just take extra care when removing the plastic grommets as they are brittle and can chip or break. I actual fabricated a bent piece of metal to help me release the tabs that hold the plastic grommet in place. Hope this helps, good luck.
| Thread Tools | |
| Display Modes | |
