Old 07-09-2011, 05:35 PM   #1
wayneskid
wayneskid's Avatar
Default CTEK Battery Chargers
Has anyone had experience with any of the newer chargers from CTEK? See http://smartercharger.com/battery-chargers/ for the full line of models. I bought the Multi US 7002. I've been reading the documentation and haven't connected it yet. My Interstate will be in long term (indoor, heated) storage in Oregon this winter and I think I will use this one for the coach batteries and perhaps get the cheaper Multi US 3300 for the Sprinter battery. The FAQ page says you don't need to disconnect the battery when charging with these models but I'm wary. Any thoughts from the forum would be appreciated. For those that have their vehicles in long term storage during the off season, what do you do to keep the batteries up?
Thanks,
Wayne
2010 Airstream Interstate Twin Bed on 2008 Freightliner 3500 170"/Tall/White~OM642 Engine~18,219 miles
2001 VW Eurovan Camper (Winnebago conversion)~65000 miles
wayneskid is offline   Reply With Quote
Old 07-09-2011, 05:59 PM   #2
glas1700
glas1700's Avatar
Default Re: CTEK Battery Chargers
I've been using a Battery Minder for years and keep it connected almost continuously to one of my cars that gets driven infrequently. It works very well and I also use it to keep two surplus 12V batteries fully charged. I haven't tried to bring a dead battery back to life and I can't comment on the effectiveness of the anti-sulfation pulses, but it never overcharges, so I'm satisfied.
http://tinyurl.com/3ozfql6
Byron
07 Navion
Old 07-10-2011, 03:14 AM   #3
Altered Sprinter
Altered Sprinter's Avatar
Thanks,
Wayne
Wayne:So far I have found the CTEK to be he ultimate charger on the market to date,
I first purchased a lesser CTEK in 2005 but since upgraded as to running a 220amp rear aux battery that needs to be kept on constant trickle charge.
The Marine 300 is as similar to the 7200 series but waterproof.
Terminals must be connected proir to mains electricity being turned on.
The smaller base charger keeps my mains battery on trickle charge or to boost the charge if and when required, as it's under 100amp.
Terminals have since been Hard Gold plated to negate the possibility of corrosion.
Pic depleted are spares if ever needed.
Richard
No Shalam - No Shalom
Old 07-10-2011, 05:40 AM   #4
Oldfartt
Oldfartt's Avatar
Hi Wayne,
There should be no issues with leaving the battery always connected. The unit which is best suited for your house battery is Ctek Muilti US 25000. It has a maximum charge rate of 25 Amps. Once the battery is charged it goes into a maintenance mode.
Quote from Ctek;
" Ripple describes the quality of the current and voltage. A high current ripple heats the battery and shortens its life. A linear charger has a current ripple of 70-400% which is much larger than the maximum 5% for a modern sealed battery. High voltage ripple could harm other equipment that is connected to the battery. MULTI US 25000 delivers voltage and current with very low ripple. The battery has a long service life and there is no risk of damage to other electronic devices connected to the battery."
Richard, The M300 is not available in USA as it is a 220 to 240Volt device.
I have a Ctek D250s Dc to DC charger to go in my new rig. It is designed to charge house and engine battery from solar panels and engine alternator. It is an MPPT device as well as desulphating function. I also have a AC Mains to regulated 15Volt DC power supply which can be switched automatically in place of the solar panels. This technology from Ctek is brilliant. All you need in one box.
Cheers
Ross
Old 07-10-2011, 04:06 PM   #5
wayneskid
wayneskid's Avatar
Ross,
"The unit which is best suited for your house battery is Ctek Muilti US 25000. It has a maximum charge rate of 25 Amps."
Since I'm looking primarily for a maintenance charge function while the vehicle is in storage, I hope the much cheaper Multi US 7002 which provides 7 A charge current will work for me. What are your thoughts on this?
Thanks,
Wayne
Old 07-11-2011, 06:48 AM   #6
Oldfartt
Oldfartt's Avatar
Hi Wayne,
Yes the 7002 will be fine for your application. It will just take longer to do a full charge if the battery is discharged. Good choice.
Cheers
Ross
Old 07-11-2011, 11:46 AM   #7
teamtexas
A Dad owner with a '03
teamtexas's Avatar
I have and have used the CTEK 7002US for about a year and it has worked great. I keep it connected at least 75% of the storage time. It has maintained my (2) 100 ah agms without fault.
Dan
Old 07-11-2011, 01:43 PM   #8
wayneskid
wayneskid's Avatar
Dan,
Looks good; I think I will mount inside the batt box as well. ! How do you route the AC cable when your van is in storage?
Wayne
Old 07-11-2011, 03:01 PM   #9
teamtexas
teamtexas's Avatar
My routing is very low tech....out in the great wide open! AC cord plugs into the outside inlet for power.
Dan
Old 07-12-2011, 06:51 AM   #10
Altered Sprinter
CTEK Chargers now available from your Mercedes Sprinter dealership.
Charger 3.6A B6 754 2028
Charger 25A B6 754 2027
Richard
