Old 06-20-2011, 08:47 PM   #1
bigdog203
Default 2004 sprinter transmission does not shift. blown brake fuse!!
Hi i have a 2004 3500 with 148k on it and the transmission shifter does not shift from park to drive or reverse. I checked the fuses and the rear brake fuse was blown, also effecting my rear brake lights. I'll replace the fuse and everything will be ok for 2-3 days and then it blows the fuse.
Has anyone had this issue before? My mechanic told me it was the shifter shorting it out! $500 part to fix!
Help!!
bigdog203 is offline   Reply With Quote
Old 06-21-2011, 12:59 AM   #2
mendonsy
mendonsy's Avatar
Default Re: 2004 sprinter transmission does not shift. blown brake fuse!!
It is possible that the shifter is the problem, but more likely to be a wire to the rear lights that is intermittently shorting out. Once the fuse blows you cannot shift out of park because the transmission does not get a signal from the brake light switch. The Sprinter has a history of issues with the wiring harness. Well worth doing some inspection before you part with $500.
2006 Mercedes NAFTA 2500
140" hi roof ~110k miles
DAD
Bill's glow plug mod
My daughter's Pet Mobile
Old 06-30-2012, 11:54 PM   #3
jpoke5
ok, have you had any luck with this??? same troubles....
Jeff
2003 2500 sprinter 158". Saukville,WI 53080
http://www.sprinterpartsauctions.com
jpoke5 is offline   Reply With Quote
