Old 05-24-2011, 11:51 PM   #1
llstoff
llstoff
Default Sounds like a jet engine
I went to pass someone today, and my van sounded like a jet engine.... what the heck is that??? turbo, EGR valve, turbo resenator???? boost is not the same...
llstoff is offline   Reply With Quote
Old 05-25-2011, 12:30 AM   #2
1hen2ducks
2006 SHC & DAD owner
1hen2ducks's Avatar
Default Re: Sounds like a jet engine
Possibly it was your fan spinning up. What was your FWT (Fahrenheit water temp)?
T1N 2006 shc <<^> Freightliner
BMW R1150RS "Pearl"
Suzuki DRZ400 Black
Various other temporary thrills
1hen2ducks is offline   Reply With Quote
Old 05-25-2011, 02:10 AM   #3
llstoff
llstoff
Water temp is normal, boost is in and out. Get a boost, then sluggish, then more boost etc... pretty goofy. Never heard this sound before, whistling. Just changed the EGR, and O2 sensor two months ago. 534,000 miles on it. Maybe she's just tierd?
Old 05-25-2011, 03:48 AM   #4
chris118
chris118's Avatar
I had the same sound a couple of times before I went into limp mode and then the check engine light went on.
My one of turbo hoses (not the resonator) had a leak.
2004 2500 118wb low roof cargo with 202,000miles, koni's all around,riding on lt235/75r15's
chris118 is offline   Reply With Quote
Old 05-30-2011, 04:02 AM   #5
JohnForde
Could it be your Espacher heater/furnace? Mine sounds like a jet engine.
JohnForde is offline   Reply With Quote
Old 05-30-2011, 04:39 AM   #6
icarus
Sounds like a cracked turbo hose somewhere.
Icarus
Old 05-30-2011, 02:44 PM   #7
1hen2ducks
1hen2ducks's Avatar
My "jet engine" was a small incision-like crack in the top charged air hose; right out in plain sight but you couldn't see it unless you squeezed the hose and looked carefully.
I wrapped a few tie-wraps around it to keep it closed and the jet engine noise went away.
I replaced all of the turbo charged air hoses after that. If one's bad, all are suspect.
"Squeeze your rubbers"
Be Well,
1hen2ducks
BMW R1150RS "Pearl"
Suzuki DRZ400 Black
