Old 05-08-2011, 04:35 AM   #1
BENDA
Default where is fuse block 3?
Hi everyone my 316 has fog lights fitted, but they don't come on.Looked at manual which says fuse 5 in fuse block 3 is the fuse, decided to check it but can't find fuse block 3.Can anyone help
ben
BENDA is offline   Reply With Quote
Old 05-08-2011, 03:53 PM   #2
hkpierce
'02 140 Hi BlueBlk Pass
Default Re: where is fuse block 3?
Using Search for "fuse block 3" I found this: http://sprinter-source.com/forum/showthread.php?t=9058
Old 05-09-2011, 02:29 AM   #3
BENDA
Hi, thank you hkpierce,I had no trouble finding fuse blk 1and2 I also looked under the drivers seat,but no fuse blk 3,page 8w-11-5 shows a fuse blk with 3 columns of 9 fuses which is bigger than fuse blk 1and2 but I can't find any sign of it.I have no fuse/relay blk near the battery,seems the wiring circuits shown in the manual are misleading or maybe useless.If anyone has any suggestions I;d appreciate it.
ben
Old 05-09-2011, 02:40 AM   #4
Altered Sprinter
Altered Sprinter's Avatar
Benda missed this one! Question do you have active fog lights. there is a dual headlamp switch on your dashboard right hand side. for front and rear fog lamps it was an option only.
If you only have a single icon switch for rear fog lamps then you do not have front fog lamps. as the headlights have different numbers for fog lamp installation.
Richard
No Shalam - No Shalom
brassarl (05-10-2011)
Old 05-10-2011, 03:16 AM   #5
BENDA
Hi Richard,my switch has two ikons, top one has two light symbols back to back with crosshatched squiggly lines,the bottom only one light symbol and squiggle,the switch is a rocker with three positions.
benba
Old 05-10-2011, 03:44 AM   #6
Altered Sprinter
Then the fuse is under your steering column, but you may have a relay gone, and that's on the side of your drivers seat.
If relay is blown ! you need to do a continuity test between relay and primary fuse for voltage.
Richard
Old 05-10-2011, 04:35 AM   #7
BENDA
Thanks Richard, Your blood's worth bottling. I'll have a go at tracing out the relay to-morrow.
again many thanks ben
Old 05-10-2011, 05:08 AM   #8
Altered Sprinter
Yo' a Vampire.
Ben this thread may help you a tad more sorry I don't have the front fogs 800 dollars per headlamp Australian forget it.
Hope this helps you find your way through the rats nest of confusion.
Rear Fog Lights - Sprinter-Forum Seek as a circut diagram somewhere I'll pm him. he can help you more than I can
PS you have his blood .
Richard
Old 05-10-2011, 05:22 AM   #9
geoffs
2003 T1N 316CDI LWB
geoffs's Avatar
Hi Richard,
A bit OT but, where can you get the blank plastic part to fill the switch holes when you remove switches for some reason?
Geoff
geoffs is offline   Reply With Quote
Old 05-10-2011, 05:43 AM   #10
Altered Sprinter
Originally Posted by geoffs View Post
Hi Richard,
'Benz and pay through the nose or get them from Chirs cheaper and cheaper in the States even .
Dodge. Benz have two different numbers, on these parts..
Richard
