Old 05-01-2011, 03:43 PM   #1
jpoke5
Default mixing tires?
I have a 03 2500 high roof 158" running kelly safari m+s 225.75r/16" load range d tires on the front. The right front is down pretty far on tread and the right front is about brand new. Is it safe to run a differant tire brand on the right front if the tread pattern looks about the same.
want to replace with a michelin ltx a/s 225 75 r16 load range e. Just for a while until I can get some rubber.
Jeff
2003 2500 sprinter 158". Saukville,WI 53080
http://www.sprinterpartsauctions.com
jpoke5 is offline   Reply With Quote
Old 05-02-2011, 04:12 AM   #2
NelsonSprinter
Nelson BC Sprinter Owner
NelsonSprinter's Avatar
Default Re: mixing tires?
Opinion only : All tire changers and tire manufacturers recommend you never mix tire models .
In your case I personally would, if money is limited and current tires are at such different tread depths, making them more equal may be safer, but replacing both front is better, and using 1 old as your spare
