Old 04-24-2011, 11:41 AM   #1
Gulf SV
Kevin Burns
Gulf SV's Avatar
Default fuel gauge stuck on empty
Fuel gauge is stuck on empty after I fueled up a couple of days ago. It was a pretty miserable night, and I can't remember if I shut the truck down when I fueled. Everything was good before the refueling, and I've run several restarts since then. Anyone have an idea? Thanks.
Kevin Burns
motorcycle racing freak
06 Freightliner 2500 SHC 158"
255,635 m / 411,404 km
Gulf SV is offline   Reply With Quote
Old 04-24-2011, 12:26 PM   #2
Default Re: fuel gauge stuck on empty
FWIW. I fueled up with the engine running once. It took quite some time for the gauge to actually work itself up to the full mark, but fueling with the engine on didn't cause it to stick at empty. I figured the delay to get to full was related to a dampening circuit. Good luck. vic
Old 04-24-2011, 01:25 PM   #3
mendonsy
mendonsy's Avatar
Nothing special about the Sprinter fuel gauge. It is a variable resistor wired between pins 1 and 10 of C1 on the instrument cluster. Maybe a wire is disconnected??
2006 Mercedes NAFTA 2500
140" hi roof ~200k miles
DAD
Bill's glow plug mod
My daughter's Pet Mobile
Old 04-24-2011, 04:32 PM   #4
Gulf SV
Kevin Burns
Gulf SV's Avatar
Thanks. I'm back home now, so maybe I'll take a look. I figured maybe a float level got stuck since I ran it right to empty. Guess I'll unload and find a bumpy road first, then look into the instrument panel. i did refuel when i got back into town, but the gauge still indicates empty. Oh, how I dislike coincidences.
Edit: I just looked through the service manual, and it appears that this might be a DAD issue. A good place to start...
Kevin Burns
Old 06-05-2011, 01:38 AM   #5
Gulf SV
Kevin Burns
Gulf SV's Avatar
Well, I was kind of slow getting around to this issue, and I'm still looking for some help before I tear deeply into it. The fuel gauge is tuck on empty and the low fuel light is on. The tank is definitely not empty. I ran a diagnostic with my DAD, and there is no indication of an issue.
Has anyone else experienced this? any thoughts to share before I decide to drop the tank? Many thanks ahead of time to the problem solvers out there.
Kevin Burns
Old 06-05-2011, 02:43 AM   #6
Kevin,
No experience because mines been working fine so far. Here's some info which may help. It's probably worth checking for resistance back to (from?) the sending unit before dropping the tank. Fig. 121 shows an earlier model without fuel pump. Note the comment about open circuit in the wiring. Good luck. vic
Edit: The float could be stuck? What about trying a rubber mallet bumped up onto the bottom of the tank just under the sending unit? The plastic tank will flex and maybe send a wave of fuel up into the float. This is a guess.
cstefan (06-06-2011), Vagabondage (06-23-2015)
Old 06-05-2011, 03:21 AM   #7
Colorado_Al
Colorado_Al's Avatar
I'm a big fan of "percussive maintenance". If it isn't working, hit it hard with a hammer. If it doesn't work after that, time to take it apart and fix what you just broke, and hope at the same time it fixes what was wrong in the first place.
2003 T1N 158" cargo conversion
http://sprinter-source.com/forum/showthread.php?t=13145
Colorado_Al is offline   Reply With Quote
Old 06-05-2011, 06:06 AM   #8
NelsonSprinter
Nelson BC Sprinter Owner
NelsonSprinter's Avatar
My fuel gauge only goes up to 3/4 full with a 95 liters fillup, stays at 3/4 'til 3/4 full then descends slowly like a Sprinter does, to empty when 95 liters are burned up.
I'm puzzled, but it's better than not knowing when it's empty!
'02 FL 2500 140WB Cargo door windows, 15" Alloys, LT235/75R15-E Nokian Rotiivas, Nokian Hakka C studded winters, Curt 4 hitch, 3.72 rear with 30MPG Cdn GDE ECO Tuned. . . I am NOT a MECHANIC, I just play one online. I also drive a MB Smart CDI.
Old 06-05-2011, 11:59 AM   #9
Heading northbound I-190. Grand Island Bridge which is only one lane each way because the other bridge is down for maintenance. Just about to the top with my 1974 full size Dodge when I sputter to a stop. Traffic backs up behind. Fuel gauge is about 1/3? No restart.
I go back to see if I can get nudged up over the top of the bridge. What I see right behind is a little old lady just peering over the top of her steering wheel with both hands clenched tightly on the wheel. Scratch that plan.
See the on-station tow truck at the bottom start to mobilize. I'm thinking a $100.00 tow and I'm cheap. Open the driver door, push on the van and feel it rock a bit. Reach in, put shifter to neutral and proceed to slowly push that van up over the rise, jump in, roll down, hit the traffic light yellow, cross over and just barely roll to the open gas station pump. Crisis averted. How lucky can you get?
You can take that to the bank. If only my gauge had stuck full or MT, maybe I would have noticed.
It's a science. This is just part of the hammer inventory I keep in my lower toolbox drawer.
mendonsy (06-05-2011)
Old 06-05-2011, 06:10 PM   #10
Ryan S
Ryan S's Avatar
sometimes it takes a few miles for my fuel gauge to bounce back all the way to the full level, but it sounds like yours may be electrical
Ryan S is offline   Reply With Quote
