Old 12-21-2010, 09:30 PM   #1
sprinterworx
Default Battery/Alternator go to workshop
Hi fellow sprinter enthusiasts.
I have an issue with the electrical system on my sprinter van. It is a 2007 Dodge badged sprinter 2500 diesel.
Here is what's going on.
The battery alternator angry red light came on and van lost power while driving. I had though the engine smelt funny, which is a telling sign your alternator is bad (smells like a dead rat my shop teacher once said) so I replaced the alternator, without testing, because autozone, oriely's, the dealer and pep boys had no way of telling if the alternator was functioning due to the funny terminals on the bottom. After replacing the alternator the van ran just fine for 20 days and then exhibited the exact same problem. I limped it home on what little power it had left and then plugged it into a trickle charger to drive to my auto shop the next day. Upon starting it the next day, it struggled, and then the glow plug coil light on the dash came on and the check engine light came on. I plugged in the OBD2 and it told me the glow plug circuit was malfunctioning along with glow plugs 1 2 3 4 5 6.
I had the battery checked by a professional battery checker at pep-boys to see if a cell had fused or the battery was bad, it checked out okay. I replaced the alternator with a brand new oem and checked it this time while disconnected to the battery. Putting out 15.6 volts, more than enough to charge a battery under normal conditions, I bolted it back on. The battery seemed to hover around 12.2 volts climbing a little and receding a little. But the ominous red "battery/alternator Take to workshop" still displays on the errors after countless resets and battery disconnects. I tried disconnecting the auxiliary heater switch (it was said in the forums this might be stuck on causing a power drain), and still the light remained on. On a side note, the auxiliary heating switch led stopped lighting up after this problem started occurring.
Any help on this would be appreciated before I spend 500 dollars on a glow plug circuit.
sprinterworx is offline   Reply With Quote
Old 12-21-2010, 09:57 PM   #2
Default Re: Battery/Alternator go to workshop
Just having the Alternator "die" (fail to produce output) should *not* affect the Sprinter's running performance.
(quick test: disconnect alternator, start engine .... engine should run just fine until the battery drops below 10v)
So it certainly sounds like *something* that can consume a LOT of electrical energy is coming on and staying on...
consuming all of your alternator's output (i think you'd HEAR the starter motor if it were the culprit).
The glow plug system certainly could do it, but disconnecting the glow plug relay would remove it from the running, too.
Hm... maybe it IS the starter.
extensive diagnostics required.
good luck
sprinterworx (12-21-2010)
Old 12-21-2010, 10:04 PM   #3
72chevy4x4
anyone know the current draw of the preheater circuit (not even sure of the proper name)?
72chevy4x4 is offline   Reply With Quote
Old 12-21-2010, 10:29 PM   #4
sprinterworx
good luck
It's true I was able to drive the van home until it dropped below 9 or 10v on battery power. It starts and runs just fine on battery with out the alternator connected.
I'll disconnect the glow plug relay and see what is what. I can't hear the solenoids in the starter motor running or anything from the starter for that matter. I'll test the glow plug theory and get back to you.
Old 12-21-2010, 10:32 PM   #5
sprinterworx
does anyone know where the Glow Plug Relay/Circuit is on the NCV3?
Old 12-21-2010, 10:42 PM   #6
Isn't the 2007 NCV3 model included in the problems which have surfaced with the battery/starter cable design? Might be worth testing. vic
NAS (N. Amer. Spec) 2004 140 2500 >295,000 mi.DAD Paint=Arctic Whitewash Brushtone Grey
Don't expect much from me. I've forgotten much of what I once knew.
Old 12-22-2010, 12:17 AM   #7
shanemac
shanemac's Avatar
This thread may help i know with mine i was getting a smell.
http://sprinter-source.com/forum/showthread.php?t=13606
2007 Dodge sprinter 2500 NCV3, 144, high, no side or rear glass,suspension seats comfort version with arm rest,heavy duty front and rear sway bars,4.10 gears,parktronic system, booster heater,axillary heater,cruise control.
shanemac is offline   Reply With Quote
The Following 2 Users Say Thank You to shanemac For This Useful Post:
Aqua Puttana (12-22-2010), sprinterworx (12-22-2010)
Old 12-22-2010, 06:53 PM   #8
sprinterworx
@shanmac, I wish i had read your post yesterday, it probably would have led me to the culprit faster.
I chased the voltage drop from the alternator line to the starter motor where it was 2.4 volts on one side of the 300 amp fuse and 12.4 on the other side, the red herring was the glow plug problem caused by the fuse being partially fried. We spent 2 or three hours ripping apart a glow plug relay that had no business being ripped apart. We had to epoxy it back together, didn't look like a 500 dollar part to me. as you can see from the pictures, the jacket on the wire was really corroded/burned. Why this happened is still a mystery. Perhaps a bad alternator? As result of shanmacs problems I'm wondering if the wiring and jackets are faulty from the factory. There is no reason a 3 year old van should be doing this.
Old 12-22-2010, 07:52 PM   #9
shanemac
shanemac's Avatar
No problem...glade you got issue sorted out. Will you be ordering a new OEM cable or fixing what you have or getting a new cable set made up? Thanks for the pics.
Old 12-23-2010, 10:36 PM   #10
sprinterworx
We have some ought gauge wire hanging around for our car stereo installation, we'll crimp and make our own. After I've seen how the sausage is made, I'm sure mine will be better. We live by the mantra, you are the best mechanic for your vehicle.
The Following User Says Thank You to sprinterworx For This Useful Post:
shanemac (12-24-2010)
