Old 11-08-2010, 08:21 PM   #1
veganxxx
Default no defrost
The past few times it's rained I noticed my window fogging up even though the vent was in the defrost position. Then I realized that the defrost vents were not opening and changing the vent selector did not change what came out where. Any ideas? Is this a common problem?
veganxxx is offline   Reply With Quote
Old 11-09-2010, 01:39 PM   #2
2002sprinterman
Minnesota
2002sprinterman's Avatar
Default Re: no defrost
I am anxious to hear what others jump in with to your issue as I don't think my defrost is working right either.
Kevin
2002 Sprinter 2500HC 140" wb short top and only 281,000 miles on the turbo diesel!
2002sprinterman is offline   Reply With Quote
Old 11-09-2010, 02:11 PM   #3
You may find some direction here:
Cheap Tricks
http://sprinter-source.com/forum/showthread.php?t=4827
Go to post #20 - Heater Control Cable Fix
There may be other heat control repair threads if you search from the blue bar.
I have a condensed thread for both the Stoopid Things and Cheap Tricks to make it a bit easier to scroll down to see if there's help to be found in those threads for any future problems. Good luck. vic
Don't expect much from me. I've forgotten much of what I once knew.
Old 11-10-2010, 08:55 PM   #4
jmoller99
Own a DAD ODB2 Unit.
jmoller99's Avatar
You might check your cabin filter. I had no air flowing to my front window until I changed mine (this part is in the engine compartment). Its easy to forget about changing these.
Old 11-11-2010, 02:45 PM   #5
veganxxx
The problem was the cable was not in the retainer near the rotating plastic mechanism that controls the defrost open/close functions. Now I won't have to towel off the window when it rains!
