Old 08-17-2010, 12:22 PM   #1
van_pire
Default Mercedes-Benz Sprinter has now BlueEfficiency
Mercedes-Benz BlueEffciency, We know this label from the passenger car models this has now expanded to commercial vehicles.
Available now, two different Sprinter BlueEfficiency variants are available with different engines.
The first has a new 2.2-liter four cylinder common rail diesel engine that is available in 95, 129 and 163 hp variants. Torque ranges from 184 lb-ft to 265 lb-ft. Electric on-demand control of auxiliary units such as the oil pump, alternator and piston-cooling oil spray reduce fuel consumption as they only consume energy when they actually need it
The Sprinter is also available with a 156 hp natural gas fueled four cylinder engine. Sprinter NGT with mono-fuel or bi-fuel natural gas drive and can also run on gasoline.
All BlueEFFICIENCY models also include the ECO start/stop function.
The ECO start/stop function shuts down the engine. When the driver steps on the clutch pedal or releases the brake so that the vehicle begins to roll, the engine is promptly restarted.
van_pire is offline   Reply With Quote
Old 08-17-2010, 12:55 PM   #2
damien89
Default Re: Mercedes-Benz Sprinter has now BlueEfficiency
So in other words it means that adblue is needed right?
damien89 is offline   Reply With Quote
Old 08-17-2010, 12:58 PM   #3
Altered Sprinter
Altered Sprinter's Avatar
Welcome to the forum
Which country do you hail from? NAFTA Sprinters are bluetec not blue efficiency V6 detuned from the Euro variant with a lower Nm and auto only.
July 2009 316 to 516 120KW =163 Hp @3800 rpm
Max torque 360 Nm @1400-2400prm
manual transmission 6 speed ECO wide gear toothed.Auto optional.
NGT is stalled in Australia as to one current NGT station in Melbourne.
4x4 also available in all variant's and options, plus the SUSI 4.9 T 4 series vans
Richard
No Shalam - No Shalom
Old 08-17-2010, 02:36 PM   #4
mackconsult
mackconsult's Avatar
Sounds like more things to go wrong.
97 XR600R Honda Dual Sport Motorcycle
98 18' Avon RIB w/ 90 HP 4 stroke Yamaha
95 TDI Passat VW Wagon
05 2500 140" normal height sprinter van w/ veggie oil conversion kit
08 Laser Pro #194171
Vancouver, Washington, USA
Sail Smart, Sail Hard, Then think about Sailing Fast !!!!!
http://www.mackconsult.com/
Some day I will sell everything, buy a cascade 36 or a cal 40 sailboat, and turn left at the Columbia River Bar !!!!
mackconsult is offline   Reply With Quote
Old 08-17-2010, 03:07 PM   #5
damien89
Hi, i am from Malta Europe. I've been reading many threads on this forum as probably i will be buying a Sprinter transfer/travel next year to work as a minibus.
So blue efficiency does not mean that it requires adblue to work right?
By the way great forum with lots of interesting info on sprinters!
Old 08-17-2010, 11:27 PM   #6
Altered Sprinter
Hi : Malta will and does have the latest of Blue efficiency engines and transmission choices if you order a V6 140 kW 190 Hp 440 Nm /Auto is the only option on this engine
I'd go for the 316 cdi it's more fuel efficient.
You do not require ad-blue as a requirement based on European oils and fuels.and current Euro 5 to 2011 EEV Euro 6 emission rulings. to 2016.
Richard
damien89 (08-18-2010)
Old 08-18-2010, 08:02 AM   #7
damien89
I will probably be going for the 516 cdi ex long model as i will only buy a sprinter in manual trans.
Thanks for the info!
The Following User Says Thank You to damien89 For This Useful Post:
Altered Sprinter (08-18-2010)
Old 08-18-2010, 08:22 AM   #8
Altered Sprinter
the 316 cdi 3 series is your best option as to power and fuel on demand when needed most,with the all new OM 651 4 inline engines
Richard
Old 08-18-2010, 08:49 AM   #9
damien89
Richard
Yes i know that but the 316 is 3.5t and i need the 516 because its a 5t. Here in Malta the 516 ex long we make them 23 seater minibuses. The more people you fit in it the better they pay me per trip.
I will probably be buying one just like this:
