| Sprinter Talk General discussion about anything and everything about Sprinters. |
re: Member
Twice now i have had the back doors on my van stick closed, both times after washing it on a hot day. The seals get soft and stick the doors together like glue. It is damaging the seals, tearing out small chunks that get bigger every time it does this. What is the best, longest lasting solution to this problem?
I would assume this could be a problem on both series of van, has anyone else suffered this? I have had it happen on other vehicles, but not quite so severely. Jef
2008 Freightliner 2500/170"/High Roof, VandaBlue |
#2 | |
That'll teach you to wash that van too much.
Just kidding.I used Dow Corning silicone grease on my side door because it was freezing closed sometimes in winter. (Why did I feel the need to add winter... like it would happen in summer. ) It worked so well I've since applied it to my other doors.Anyway, the stuff I had was from old stock we used to grease high voltage insulators back in the day. It is also used in laboratories for lubing seals, stoppers, etc. If you can't find silicone grease you might try some spray on a rag and applying it to the rubber. I hate to spray silicone all over because it is nasty stuff to get rid of if you ever need paint work done. Good luck. vic Quote:
NAFTA 2004 OM647 140 2500 Std Roof >255,000 mi. Paint=Arctic Whitewash DAD "My opinion and worth everything you'll never pay for it." is expressly implied. Keeping me on topic will be as successful as herding cats. Anyone can hold the helm when the sea is calm. Publilius Syrus "There are only 10 types of people in the world: Those who understand binary, and those who don't." HaWiiLuVeR Some people have 10 years experience, others just 1 year 10 times. Last edited by Aqua Puttana; 08-06-2010 at 02:20 AM. |
#3 |
re: Member
I've tried the spray silicones on the Honda and the Sprinter. It needs to be re-applied weekly to work. I'm not that convinced the grease would be much better on that count, but that was my thought for the next thing to try.
And that was it's yearly bath i was giving it. It needed it.
#4 | |
http://properboatcare.com/prmapowite.html Another off the top of my head untested possibility. There is a tape which is used to fasten the thin plastic pipe insulation covers in place. I believe Tedlar was one of the pioneer brands. It is very stable, sticks to shiny surfaces forever, comes in white color (Oops, noticed your avatar. It may come in gray also. With the doors closed it shouldn't show.), and doesn't degrade in the weather.http://www.venturetape.com/product.p...&cat=42&page=1 I'm quite certain it's available from McMaster-Carr. It would be a bit of a tedious project to apply, but maybe installing some Tedlar tape on the gasket mating surface lip would permanently cure your problem. As I said, it would be an experiment. I'm 99.9% certain the rubber would not stick to the "unsticky" Tedlar tape side. Good luck. vic
#5 |
surviving member
Does it stick at other times of the year? If it's only at washing time, maybe let it dry better before closing up. Only a guess.
eb
2007 2500 deisel. 170 inch wheel base, long and high. Stripped down for hauling freight. 507,000 one owner miles, 7,000 miles per month. |
#6 |
Not Suitable w/220v Gen
You might try Krytox.
http://forums.vwvortex.com/showthrea...tox-Lubricant& The first few postings are contained in the attached PDF. -Jon |
#7 |
2005 140" low roof
303 Aerospace Protectant
It wont break down EPMD seals over time the way petroleum or silicone based "protectants" will. Fantastic fan includes samples with the fan and recommend treating the lip seal with 303... Cheers George |
#8 | |
re: Member
It gets washed, sits in the sun to dry, and then the doors are stuck. Maybe leaving the doors open after washing, but i've never had to do that before, so it's a new habit to learn. Thanks Vic, I like the idea of the slick tape. That deserves some research. Too bad about the color, though. Clear would be nice. Maybe it will help with our Honda Odyssey side doors. If they sit more than a week, the electric motors can't break the seal to open them. Gotta love those power doors Jef
| Thread Tools | |
| Display Modes | |
