We Recently bought a 2005 Pleasure-Way sprinter and experienced a substantial roof leak that all but defied locating it. After considerable sealing around vents etc. and having the AC gaskets replaced, we still had a leak. I finally found it in the factory seam.
Anyone had this problem and how did you fix it? |
| The Following User Says Thank You to Ruby For This Useful Post: | seans (02-18-2010) |
#2 | |
But that could entail major works if you have insulation and a headliner to contend with. Or the easy way out would be to just clean the joint and seal it with Sikaflex sealant.
For having lived long, I have experienced many instances of being obliged, by better information or fuller consideration, to change opinions, even on important subjects, which I once thought right but found to be otherwise. Benjamin Franklin LET THE FACTS SPEAK FOR THEMSELVES!: Science - Here are the facts, now what conclusions can we draw from them? Religion - Here are the conclusions, now what facts can we find to support them? |
| The Following User Says Thank You to bladerunner For This Useful Post: | Ruby (02-19-2010) |
#3 |
One of the members here had his roof sprayed with a bedliner type material that not only seals it completely but protects it from those nasty branches that scratch up the High tops. I am thinking about doing that to my van as I have the same seam leak. Until then, I just cleaned it out good and sealed it with 3M 4200, which worked great.
2004 140" 2500 SHC window van |
| The Following User Says Thank You to WeBeGone For This Useful Post: | Ruby (02-19-2010) |
#4 |
The paint looks damaged and the metal rusted. I'd sand back the paint maybe 4-5mm, taking off any rust in the process, then a dab on a light coat of an etching auto primer. Sherwin Williams 988 is pretty good - spray into a puddle elsewhere and use a small brush to apply to the metal - so no overspay. It has corrosion inhibiters. The 3m 4200 mentioned is also pretty good stuff as it will flow down into the crack a bit before setting, and it's bright white, so the repair will be less visible.
| The Following User Says Thank You to NBB For This Useful Post: | chuckspirit (02-22-2010) |
#5 |
I had a small leak around one of the roof vents probably from sitting on the lot in the AZ sun last summer. Airstream recommends Sikaflex 221 which is a polyurethane sealant adhesive and has the benefit of being paintable unlike silicone. It's also on sale for $9/tube here
2009 Airstream Interstate 2006 E320CDI 2000 F350 CC 4WD Powerstroke 1996 Passat TDI |
| The Following 2 Users Say Thank You to ben322 For This Useful Post: | chuckspirit (02-22-2010), seans (02-19-2010) |
#6 |
| The Following User Says Thank You to Altered Sprinter For This Useful Post: | chuckspirit (02-22-2010) |
#7 |
I have faced same problem,I applied polyurea coatings on the roofing for the leakage problem.
#8 |
I have applied Ultimate linings polyurethane spray for leakage problem.It's result amazing.
| The Following User Says Thank You to handsome For This Useful Post: | Ralph&Betty (02-04-2013) |
#9 |
Thank you everyone who posted about this and offered solutions. I realized that water staining at the bottom of the headliner in my 2006 passenger wagon near the center was caused by a similar leak in a roof seam. It has been temporarily addressed with a bead of caulk. While I was applying the bead, I noticed that a thin crack in the paint extended past the line of rust along the seam. So, if you have this problem and decide to repair it and not treat the entire seam, be sure to extend well past any obvious rusty area along the seam and look for a faint crack in the paint.
2006 Dodge T1N 158" Tall Roof Passenger Wagon w/Rear AC |
| The Following User Says Thank You to seans For This Useful Post: | mike_mcginn (03-25-2010) |
#10 |
Capt. Tolley's Creeping Crack Cure! It wicks into thin cracks and seams and sets up. Just about invisible on the surface. I've used this around windows to keep tiny ants out. It's a boating product for sealing decks. You wet down the deck and let it almost dry. The damp lines are cracks and the Tolley's will displace the remaining water.
2004 140 SHC Greyhound, toy poodle and a big black mutt hauler Last edited by hkpierce; 03-25-2010 at 04:49 PM. |
| Thread Tools | |
| Display Modes | |
