Need some advice. Im in the process of building an 80/20 panel bed. The last 2 feet will be on a hinge. The curved sides of the van are 67 inches across when in bed position and 63 inches across when in flip up mode. I'm toying with the idea of making "slide out" pieces (green in photo) that will rest on brackets (yellow in photo) when in bed mode. I was thinking about using a knob that you could tighten/loosen for this to work.
By doing this I can keep the brackets from needing to protrude more then an inch from the wall. Any suggestions on the Best way/sturdy way to do this with 80/20? Thanks
Dave
Dave
