geneowens1
Hello, I'm looking for advice on a furnace issue on my 2012 PW Plateau TS on 3500 Sprinter chassis. I've used the propane furnace a number of times over the winter. However, we have had some warmer weather and then a cold day - on that cold day I discovered that my furnace would not fire up. It attempted to light about 3 times and then shut off. I also discovered that the 2 burner cooktop will not light. The fridge appears to be working on propane; the hot water heater fires on propane and the generator fires and runs on propane.
Any thoughts as to the source of the problem with the furnace and the cook top???
Thanks,
Thanks,
