Douglas Hicks
My 2003 140 SHC 2500 quit last week. After an unknown time, my guys started it, moved it 1/2 mile and it quit again. I had a flatbed take it to the jobsite, where the tools and parts were unloaded and then take the van to my mechanic.
My mechanic, Paul, first check for codes, using the Snap On machine. he found lots of codes and cleared them. Paul then went on a test drive. He drove it at 35-40 mph until the engine warmed up, and then floored the engine. It went into LHM, he pulled off the road, shut off the engine and started it up again. He then drove it 35-40mph and floored the engine. LHM, pulled off the road, shut down, start up. Did it again. and again, and again. He then went to the shop, hooked the Sprinter to the Snap On machine, and found lots of codes. He cleared the codes and went for another test drive. Same results, except when he returned to the shop, Code P1187-001 was there. My book and his says "Rail pressure monitoring, The maximum pressure has been exceeded. " supposedly, the fix is to replace a fuel solenoid, the purpose of the solenoid to regulate the pressure.
Paul was not really comfortable doing things to the fuel pump, so he took it to the local Dodge shop, who only knows less than Paul. They do have the Dodge program which does read codes. After a couple of days giving my van the sunshine treatment, they took it inside the shop and parked it. The mechanic and shop foreman drove the van today. But they did not drive it like Paul did and they had no problem with my van. I think this is the first Sprinter in their shop.
That is my story and I am now depending on you folks to start making suggestions.
