Right il tell YE what i know and what I've done then YE can all shout at me
Got this van and it will not start without towing it, even when hot, it was like this when we got it, we have changed the fuel filter and the heater plugs.
Have done a pump pressure check and it's at 1460 have been told this could be du to a fault on the lp side of things in the tank as it should not be over 1050.
I have done a injector bleed off check and had no fuel out of 1 and 4, had loads out of 2 and a wee bit out of no 3, I did and non start bleed off test of 5 seconds turn over on the starter motor with a full charged battery, I did this test 5 times, 2 and 3 gave out fuel and 1 and 4 were just damp, any help would be great as I'm at a loss:
Bring back the old trucks
