| Sprinter Talk General discussion about anything and everything about Sprinters. |
#1 |
2003 dodge sprinter 2500 power lose no power up hills or at starts .changed egr and map sensor need help ???
#2 |
might be the boost pressure sensor it's what was out on my 2007 and as soon as it was changed out i got my power back.
#3 |
Any smoke from the tailpipe? If yes, what color?
'02 316 2500 SHC FTL 140 passenger, NAG1, 3.73 diff, 16" wheels, OM612 w/EGR (>275k mi.), '04 Golf PD-TDI (>110k mi.), both bought new |
#4 |
Yes black smoke not much only when i start driving
#5 |
Does it idle smooth or rough? Does the flow from the tailpipe feel smooth and continuous at idle or does it puff? If rough or puffing, then I'd suspect a bad injector or two (type2teach has posted a shade-tree test). Black smoke means too much fuel or not enough air. If not injectors, could be many things. Probably best to have someone with a capable tool (DRB-III, DAD, etc.) scan for codes and look at operating parameters to see if any are out of range.
#6 |
Own a DAD ODB2 Unit.
That also could be describing a clogged EGR valve. You may want to take it off and clean it (I have a 2002 - it uses the same EGR Valve your 2003 has - I clean mine every spring). 2002/2003 EGR Valves have a reputation of clogging up, but are pretty easy to clean. I use spray SeaFoam, others have used Carb Cleaner (I would avoid brake cleaner since it removes all oil, and you really want a little lubricant to allow the mechanisum to move freely).
Europarts SD has the gaskets (made of metal) for all of the T1N EGR valves.
2002 Freightliner Cargo. 140 WB |
#7 |
well its the damn waste gate actuator finaly figured it out . i want to thank everyone for the help .
#8 |
Is it the WGA or is it the vacuum lines not actuating it because they are cracked? If you already got it, good. Glad it was easy for you.......
07 2500 170" HR, Michelin LTX/MS 235/85-R16 add 6% over Dash mpg & 6% less milage on the odometer. Contractor Package,Heated Seats,Windows & Mirrors, 2kw True Clean Power Inverter,Ceiling Pipe & Ladder Mounts, Rear Electric Space Heat, Full Weatherguard Bins,Totes,Racks,Drawers,Cabinets Custom Welded & Fitted to maintain interior width- Aluminum Plate work Bench. Diamond plate Aluminum walls w/Unistrut mount system.Lifetime Average MPG 17.8 (includes idle time). Summer MPG 20.9/ Winter 18.8 |
#9 |
Not Suitable w/220v Gen
WGA == Waste Gate Actuator?
I didn't know US/Canadian Sprinter turbo chargers had waste gates. -Jon
2007 F/Liner 2500 Cargo Van, 144" WB, 3.92 Rear Axle Ratio, Buttons on the Steering Wheel, Contractor Package, Heated glass and seats, no spark plugs or windows in the cargo bay. US Tech info: http://www.sprintertekinfo.com US Parts info: http://epc.startekinfo.com (Subscribe to world passenger car and light transport) Americans may learn to use MB technical resources and parts information here: http://www.sprintertekinfo.com/epcdemo/start.swf |
#10 |
Turbo exhaust inlet vane positioner, which for the NAFTA '02-3s (OM612) is vacuum-actuated.
| The Following 2 Users Say Thank You to talkinghorse43 For This Useful Post: | Aqua Puttana (07-25-2012), jdcaples (07-25-2012) |
| Thread Tools | |
| Display Modes | |
