| NCV3 Talk General Discussions related to NCV3 Sprinters. |
#1 |
I want to install a sliding door grab handle on my high roof crew cab. I ordered -
1 x handle 1 x handle cover 1 x pillar molding with holes 2 x handle base moldings 2 x bolts 2 x nut/clips Seems like there is a bracket that needs to also mount to the body which will hold the nut/clips - Anyone know how to source the hidden bracket? Thanks! Dwayne
2011 Mercedes Benz Sprinter 2500 170 Crew |
#2 |
Schloss auf Rädern
Great question! I, too, have factory handles in hand, ready to install. Does anyone have any pictures of a grab handle installed on the B pillar? I see several predrilled holes, but none line up. Cambinos came with the interior panels, so no handles.
On the back doors, installation was a breeze as there were threaded nuts in the pillars. Not so on the B pillars (I have dual sliding doors).
Her name is Cambinos! She is our Schloss auf Rädern (castle on wheels). Track her development here and her adventures at Living Appalachian |
#3 |
I installed the new molding for the b pillar and clearly identified that a hidden bracket that attaches to the b pillar to allow the clip nuts to attach to would be the only way to install the handle...
Instead - I mounted the handle in the correct position and drilled small pilot holes in the b pillar using the handle hole alignment as a guide. The pilot holes basically are right on top of the rounded b plllar corner. Drilled out the holes and installed two nut rivets. Used longer bolts and attached handle directly to the b pillar - I believe stronger than the factory handle. Dwayne
| Thread Tools | |
| Display Modes | |
