Go Back   Sprinter-Forum > Regional Discussions > USA
Reply
Old 10-11-2011, 07:37 PM   #1
ifd98125
Exclamation Seattle repair shop? Hot Start problem.
Can anyone in the Seattle recommend a reliable repair shop for my 2005 Sprinter.
I am having a "Hot-Start" problem that replacing the Glow-Plugs did not solve.
ifd98125 is offline   Reply With Quote
Old 10-12-2011, 02:01 AM   #2
o.trim
Default Re: Seattle repair shop? Hot Start problem.
check the camshaft sensor. I know one guy he had the same problem for six months, until I checked his 2005 Sprinter with DAD. DAD said Camshaft positioning sensor. Sensor was replaced, problem solved. Also, that guy told me that he bought the camshaft sensor from the newer model (2007 up). He said that they are the same, the only difference is the price - for 2007-2011 more than twice cheaper.
o.trim is offline   Reply With Quote
Old 12-13-2011, 04:14 AM   #3
pyramidhvacr
pyramidhvacr's Avatar
Camshaft sensor is the first step I too know someone took a fan with him to cool down the motor / found that this $30.00 camshaft sensor was the headache after many trip to the shop never found replacing many other parts. Lots of money in the trash. And add a ground wire to motor to battery ground post. Or keep jumper cable to jump motor to battery ground post to start if you have 1 click on a relay turning the key. This is a bad grounding system. Jumping from other auto's will not help @ battery.
pyramidhvacr is offline   Reply With Quote
Old 12-13-2011, 04:46 AM   #4
Brenton
Lynnwood Mercedes spendy, of course, snotty service manager. But great mechanics. Not sure what the glow plugs would help. I'd suspect the starter?
Brenton is offline   Reply With Quote
Old 12-13-2011, 05:21 AM   #5
glas1700
glas1700's Avatar
I wouldn't doubt that that new glow plugs didn't help because they aren't necessary for a hot start. It could be one or more leaky injectors or a failing camshaft position sensor. Does it have the original starting battery? Low cranking voltage will cause non-start issues.
You have a choice of two MB Sprinter dealers nearby, MB of Lynnwood and MB Tacoma. If you head down to the Portland area, there's McCoy Freightliner and Upscale Automotive. MB dealers aren't cheap, but from what I've read, their service is decent.
Byron
glas1700 is offline   Reply With Quote
Old 12-13-2011, 03:25 PM   #6
autostaretx's Avatar
I haven't used them (i used to ferry a friend there for his Jeep), but Town and Country Chrysler on Aurora Ave N took over the area's Dodge service obligations when the local Dodge dealers collapsed.
www.towncountrychryslerjeep.com/index.htm
Old 12-13-2011, 03:43 PM   #7
jdcaples
Not Suitable w/220v Gen
jdcaples's Avatar
I sent a member with a T1N start problem to MB of Lynnwood.
They fixed it right the first time, after the independent shops wasted a fair amount of time and money experimenting.
This member is a business owner and he was happy with the result.
If it's important, take to the professionals with access to the best Sprinter information (for all US model years) and - by now - probably the most experienced shop in the Puget Sound area.
-Jon
2007 F/Liner 2500 Cargo Van, 144" WB, 3.92 Rear Axle Ratio, Buttons on the Steering Wheel, Contractor Package, Heated glass and seats, no spark plugs or windows in the cargo bay.
US Tech info: http://www.sprintertekinfo.com
US Parts info: http://epc.startekinfo.com (Subscribe to world passenger car and light transport)
Americans may learn to use MB technical resources and parts information here:
http://www.sprintertekinfo.com/epcdemo/start.swf
jdcaples is offline   Reply With Quote
Reply
